Notices
Sponsored By:
Sponsored By:
$5 Door Lock Motor (Actuator) Fix
Old 07-07-2007, 07:43 PM
jfpound's Avatar
Wha'sup peoples.
So I, as many, have dead door lock motors on my 03 coupe which is out of warranty. I was pretty dusgusted with the dealer cost of ~150 for a door lock motor especially since i know from installing alarms and power door locks (in college) that aftermarket door lock motors cost less than 10 bucks.
I bought this door lock motor:
http://www.partsexpress.com/pe/showd...number=330-010
And installed it as shown in the pics below.
- I made the bracket holding the motor (.06" thick 5052 aluminum)
- drilled a hole in the door handle housing for the rod to pass through
- clipped off part of the plastic door lock lever
- trimmed some of the plastic ribs on the inside of the door panel to make clearance for the motor.
- Cut the wires going to the factory motor and hooked directly to the new motor. You can find the wires inside the door below the speaker (take out the speaker). I brought them out the rubber boot above the speaker.
This was the passenger door. I'm gonna try the drivers door tomorrow.
Again... cost was $5... Sweet.....
The following 2 users liked this post by jfpound:
66Restomod (07-24-2014), dj714 (10-11-2012)
Old 07-07-2007, 08:06 PM
GreenGoblin's Avatar
The goblin resurrection
good fix for those that need it
Old 07-07-2007, 08:09 PM
jfpound's Avatar
Oh yea, I forgot to mention... It works like a champ
Old 07-07-2007, 08:46 PM
partyman66's Avatar
Nice job dude!
Old 07-10-2007, 01:24 PM
PHOX 2's Avatar
You are my new hero... I am having the same problem and is nice to see that you were able to fix this.
Old 07-10-2007, 01:33 PM
joe603's Avatar
Nice work, thanks!
Old 07-10-2007, 05:35 PM
can you take some pics of what it looked like orignally? cause it looks a little ghetto fab...
Old 07-14-2007, 01:43 AM
jfpound's Avatar
hahaahaaa... ghetto? Well I wasnt trying to make the inside of the door look like show quality. If you don't like it then don't do it Works for me and I bet it works at least as long as the factory crap did.
Old 07-15-2007, 08:14 AM
dTor's Avatar
What a foktard. I'm glad he's banned.
Anyway, this is the kind of stuff that needs to be stickied in the DIY section. You should PM a mod and see if they'll move it over there. You should, for the purpose of a DIY thread, take a pic of the wiring where you spliced it into the factory wiring.
Thanks for the info!
Old 07-15-2007, 06:50 PM
French87's Avatar
Great DIY! good job
Old 07-16-2007, 04:59 PM
jfpound's Avatar
Right on. When i do the drivers side I'll take a pic of the wiring.
Old 07-19-2007, 03:11 PM
oscottio's Avatar
wow, nice job!
Old 07-19-2007, 07:59 PM
Mike_Deezy's Avatar
Nice job, shouldn't this be a sticky?
Old 07-19-2007, 08:44 PM
TURBOTOM's Avatar
a.k.a kleicoupe
This should be copied to the DIY section, this is great for people who are out of warrenty and dont want to be charged a ton by the dealer.
Old 07-19-2007, 09:43 PM
Mike_Deezy's Avatar
I'm assuming that this actuator will work on other cars too right?
Quick Reply: $5 Door Lock Motor (Actuator) Fix
