Replacing the G35 sending unit - (Removing the back seats)
Old 09-20-2010, 02:35 PM
Retaliation's Avatar
The sending unit is bad on my 2004 G35. It only fills up to 3/4 on the gauge but the tank is full. I know this because I can drive for almost 200 miles after the gas gauge comes on and it still has a few gallons left in it.
Anyway, I heard that replacing the sending unit is pretty simple. Remove the back seats, unplug the wire, rotate the cap off of the tank and pull the old one out. Is this accurate? My first real question i guess is, how the heck do I get the rear back seat out of the car? Is it just held on by those four bolts at the back of each bucket seat? Also, do I have to remove two sending units or just one?
Old 09-20-2010, 02:38 PM
jutn35's Avatar
G35 Coupe
to pull the bottom back seat out , just pull up hard, there are 2 clips on both sides. you sure it wasnt the gas gauge weirdness problem that could of been fixed by using a q-tip, if your under warranty than good for you "D
Old 09-20-2010, 02:44 PM
So just pull up on the entire bottom hard? Do both seats and the console both come up or do each bucket seat bottoms come out individually?
No, I'm not. I'm not aware of that problem and the q-tip solution. What were the symptoms? Mine isn't irregular at all, it's just wrong. When the gas light comes on, I have about 8 gallons left in the tank.
Old 09-20-2010, 03:34 PM
herrschaft's Avatar
You will have to pull hard to get it to unclip. The lower part of the back seats is one piece with the center console attached.
Old 09-20-2010, 03:54 PM
nghiars's Avatar
Can you tell me more about this or do you know if there's a thread that goes into detail. TIA
Old 09-20-2010, 08:56 PM
Which side do I replace? the passenger side sending unit, or the driver side, or both?
Old 09-20-2010, 09:02 PM
WhosRich's Avatar
Dealerships can test the sending units to see which is faulty. Since you dont have any way of knowing, I'd just replace both to be safe.
Old 09-21-2010, 10:14 AM
Yeah well I doubt they'd do that for free, which is why I'm doing it myself to begin with. Yeah, I guess I'll do both. It's only $70 total for both parts. Has anyone done this before? It looks straightforward, but is there anything in doing this that I should specifically be careful about?
[edit] woops, just realized I'm in the wrong forum.
Old 09-21-2010, 12:39 PM
nghiars: apparently this q-tip procedure was explained in another thread
I'll give this a try before I go buying parts.
Old 09-21-2010, 02:30 PM
_'s Avatar
_
_ is offline
hmm off-topic, have anyone tried removing the back seats for less weight to try to even the 350Z so its lighter to go fast enough
Old 09-21-2010, 06:45 PM
av8or's Avatar
i don't think taking off the seats is enough to match the z in weight.. that and it would look hella ugly...
Old 09-21-2010, 10:16 PM
herrschaft's Avatar
It does look ugly and removing the back seat and spare tire is only around 80lbs total, nowhere near a Z.
Old 09-29-2010, 09:57 PM
Well, the q-tip procedure worked for me. I drove my car till the tank was almost empty, then followed that procedure. It took me about 15 minutes. I didn't think it did any good, but once I filled the car up, the needle went all the way up. It's the first time in two years since owning it that the gas gauge has been to the full line since I've had it.
I'm totally pumped!
Old 10-18-2010, 03:52 PM
nghiars's Avatar
Thanks!
Old 01-19-2011, 03:52 AM
TastefullyDone's Avatar
okay bad news and need help. I did the DIY and fuel will fill all the way up a bit past full which got me very excited, I set my odometer to zero at the last fill up and drove about 340 miles from full to just 1/4 tank left.....the gauge stayed at 1/4 tank for a really long time and had me concerned. I decided to fill it up even though the needle read 1/4 and well before gas light came on because...I figured getting 340 miles just seemed like a lot of miles in a g. I pump gas and fill up with 19.19 gallons!!!!! which means if had I not pulled over and filled I would have run out somewhere on the road! WTF! Why doesn't my fuel gauge drop below the 1/4 mark now to tell me I'm way low?? HELP!! I don't know if something is wrong or if I need new sending units, etc. the gauge/units were working just fine below 1/4 tank mark before the DIY so idk!!
Quick Reply: Replacing the G35 sending unit - (Removing the back seats)
