Varrstoen 2.2.2
Old 01-21-2011, 12:32 PM
Sp33dY's Avatar
Question Varrstoen 2.2.2 wheel question
Hey guys I finally decided to go with these rims the volk reps. I really like the way they look and the size and the offset options but I really need your help on selecting the correct offset. I did some searching but can't actually find anything that shows pics of what I really want I know people will give me crap for this. I really want it to look a little like they are bet in I know peoples rims look like that because they use spacers to make them fit like that but I want mine to look something like the picture I'll post. Here is the link on the 2.2.2 chart for all the offsets offered which one would look good???? 19x9.5 and 19x10.5
SORRY for using your pic just love this setup wish I had the money for it
http://varrstoen.com/VARRSTOEN%20SIZ...ART%20v2.0.pdf
Thank you
tiguy99 (01-16-2019)
Old 01-21-2011, 04:24 PM
Sp33dY's Avatar
Anyone???
Old 01-21-2011, 04:27 PM
CandlestickPark's Avatar
ill Sedan
Received 2,687 Likes on 1,448 Posts
I'm pretty sure Pat was bagged in the photo you posted of his ride, so unless you are on air your setup won't look like that.
How low are you, pic of your ride?
Old 01-21-2011, 04:30 PM
Sp33dY's Avatar
I'm going to go with Tein basic right now its stock. All I want to know is what offset would have the rims look curved like his.
Old 01-21-2011, 04:38 PM
ill Sedan
Not sure what you mean by "curved" but here is a setup you should check out. Camber and stretch aren't insane, gotta be low to pull it off though. Fenders rolled flat, not pulled.
Johnnys_Beast_Foo
Varrstoen 19×9.5 -10 & 19×10.5 -5
Project Kics spacers
235/35/19 & 255/35/19 tires
Old 01-21-2011, 05:23 PM
Sp33dY's Avatar
The way I drive I can't go that low lol but thank you that helps do u have any side pics? Or rear close up to the wheels ?
Old 01-21-2011, 08:26 PM
Xet's Avatar
Xet
Xet is offline
I got +12 all around and stretched my tires. I ended up putting 15mm spacers on the rears, and the fronts could maybe use a 5mm. If I did it again I would personally go +0 at least in the rears if not all around. Tight rims though.
Old 01-21-2011, 09:33 PM
fwdsux's Avatar
I agree. Most people seem to be running +12 or 0 offsets on 19x9.5/10.5" on 225/35 front & 255/35 rears and only roll their fenders flat without having any rubbing issues. You would want to run coilovers to even get close to the look of the car in the pic you posted...poke looks strange with wheel gap. I know you said you couldn't drive the car that low but that's just my $.02
Old 01-21-2011, 09:44 PM
erklep's Avatar
as stated, 9.5/10.5 +0 all around will fit perfectly with a roll and mild stretch. gets you pretty damn flush if you are at the right height. if youre not slammed, youll poke a bit and possibly have issues with slight rubbing.
Old 01-21-2011, 10:52 PM
Sp33dY's Avatar
What do you guys think if I ran 0 offset with a Tanabe DF210s the drop is 1.7 F and 1.3 R with maybe a fender roll.
Old 01-22-2011, 01:22 PM
g35=365's Avatar
varrstoen wheels
i bought my rims from them also, i have the te' reps. 19x9.5 and 10.5 rears.
my tires are 245/35 and 275/35, lowered on tanabes df210.
Old 01-24-2012, 12:36 PM
DeenG35M6's Avatar
hey im looking at these. 19 x 9.5 +12 and 19x 10.5 +12 . Will this work on g35 coupe lowered on 350Z htechs without rubbing or needing to roll fenders? tire size im looking for is 245/35 and 275.35. Thanks
Old 01-24-2012, 02:33 PM
XiN's Avatar
XiN
XiN is offline
Supersonic... Hypertonic
Itasha Coupe
Old thread, but I'll answer your question.
Yes they will fit.... after your rear fenders are rolled.
Old 01-24-2012, 03:22 PM
flyz's Avatar
I believe you'll need the rears rolled with +12 on 275.
Old 02-06-2013, 02:48 PM
jmoney3001's Avatar
How did this work out, I know u posted this about a year ago, but I was wondering if u did get them and if u liked it. I am thinking of a setup similar to this, I have a stock suspension, do u think it will stay clear without rolling fenders? Don't know a lot about that. Thanks, also could u post a pic with ur new rims
Quick Reply: Varrstoen 2.2.2
