FS[NorEast]: OEM ipod adapter
Old 07-03-2011, 12:01 PM
slammedgsedan's Avatar
OEM ipod adapter
SOLD
For sale is a used OEM ipod adapter. Car must be prewired and satellite ready. This unit works through ther sat plug and retains all original functions.
Old 07-03-2011, 12:03 PM
gannicus's Avatar
does it charge the iphone 4
Old 07-03-2011, 12:53 PM
Not sure if it will charge Iphone,but does charge Ipod.I'll have to find someone with an Iphone and see if it charges.
Old 07-06-2011, 12:43 AM
ray1370's Avatar
No it doesn't, you need one of these:
http://www.amazon.com/Scosche-passPORT-Charging-Adapter-iPhone/dp/B001HN6CVA/ref=sr_1_9?ie=UTF8&qid=1309926682&sr=8-9 http://www.amazon.com/Scosche-passPORT-Charging-Adapter-iPhone/dp/B001HN6CVA/ref=sr_1_9?ie=UTF8&qid=1309926682&sr=8-9
OP do you have the cable that plugs in to the sat pre-wire connector? In the pic only the one goes to iPod is shown.
Good deal on a great add-on for the stock head unit. I love mine.
Old 07-06-2011, 01:27 AM
gannicus's Avatar
Originally Posted by ray1370
No it doesn't, you need one of these: http://www.amazon.com/Scosche-passPO...9926682&sr=8-9
I have sat plug so I guess I will buy it
Old 07-06-2011, 04:10 PM
ray1370's Avatar
The sat plug does not plug in to the iPod adapter directly, there should be another cable connecting the iPod adapter to your sat plug. Without that cable the iPod adapter will not work. Make sure you'll receive that cable when you buy it.
Old 07-06-2011, 06:16 PM
Not sure what other cable you are talking about. This is the 16 pin sat plug right into ipod adapter and it works flawlessly. The only time you would need another cable is if you wanted to retain your factory sat tuner. So if you have the 16 pin sat wire(hence the prewired for sat)then you are good to go.
Old 07-06-2011, 09:02 PM
ray1370's Avatar
^ I believe that 16 pin sat plug you were referring to is the other wiring harness, which should go with the adapter. When I got mine, the cable came with it and I followed the DIY on here to connect the adapter to the sat pre-wired plug using the cable supplied. Here are some links for your reference:
FS[NorCal]: OEM Ipod Interface Adapter
http://www.g35parts.com/G35-iPod-Fac...999u7-ipod.htm
Old 07-06-2011, 10:05 PM
[QUOTE=ray1370;5984867]^ I believe that 16 pin sat plug you were referring to is the other wiring harness, which should go with the adapter. When I got mine, the cable came with it and I followed the DIY on here to connect the adapter to the sat pre-wired plug using the cable supplied.
I see the cable you refer to, All that is is a 16pin female to 16 pin male extension cable. All g's that are prewired this 16pin connector will plug in directly and play normal. The sedan has it behind the pass rear seat finisher and the coupe under rear by the amp. On my sedan I simply removed the back seat, unmounted the pre-wire harness and ran it under the carpet to the center console,mounted the ipod adapter and was in business in 20 minutes. If someone needs the extension cable I have one or sat(out) cable allowing the use of the sat unit and ipod I have them both but you do not need them to get this to work.
5 foot extension cable($20)
Satellite Out Cable Allows retention of Factory sat tuner when adding ipod adapter($20)
ray1370 (07-07-2011)
Old 07-07-2011, 02:08 AM
ray1370's Avatar
Ah didn't realize it's just an extension cable. Thanks for the info.
Still a great deal with all the cables, I'm sure it'll sell fast. Good luck!
Old 07-08-2011, 04:29 PM
Bentley2012's Avatar
still for sale? im in north nj and would be willing to buy asap.
Old 07-09-2011, 07:15 AM
PM sent
Old 07-11-2011, 07:21 PM
bump
Old 07-13-2011, 10:34 PM
IHeartInfinitiG's Avatar
Can you control the iPod via a after market navigation system ?
Old 07-15-2011, 06:16 PM
Sold
EnCr1pt3d
07-08-2019 02:48 PM
willdogs
12-08-2015 11:32 AM
Quick Reply: FS[NorEast]: OEM ipod adapter
