75,000 mile maintenance, any advice?
Old 08-30-2011, 03:43 PM
FRISCO6MT's Avatar
Hello,
I just hit 75,000 miles on my 04 6MT coupe and wondering what you recommend in terms of maintenance, part replacements, or any thing else to look for at this mileage. It's completely stock...KN air filter at most.
The drive is starting to feel a bit bumpy so I'm thinking of maybe replacing shocks...
What do you guys advise? Thanks for your input!
Old 08-30-2011, 04:28 PM
bluedevils95's Avatar
If it's not broken, don't fix it.
Did you drive your G for 75k?
Old 08-30-2011, 04:52 PM
FRISCO6MT's Avatar
Heard that, nothing broken yet...just wanted to get a jumpstart before it does.
bought it at 31k...put on 44k myself.
Old 08-30-2011, 05:51 PM
VeRDE35's Avatar
In the same situation. All I have done is new trans fluid, diff fluid, timing belt and I think that's it.
FRISCO6MT (08-30-2011)
Old 08-30-2011, 05:53 PM
acee's Avatar
Addict
transmission oil change
rear differential oil change
oil change if you havent done it
change spark plugs if you havent done it since 31k
air filter
idk if im missing anything else but im just suggesting what i did for mines im at 70,500 and i bought mines at 61,000. I'm planning on changing my belts soon as well as my brake fluid and does anyone know how often should you change you coolant fluid?
Old 08-31-2011, 01:20 PM
VeRDE35's Avatar
Oh changed my coolant to and I heard somewhere that compression rod bushings need to be changed
FRISCO6MT (08-31-2011)
Old 08-31-2011, 01:30 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You did a timing belt? On a VQ35DE motor? That would be quite difficult since we have a chain that will outlast the motor and doesn't need to be changed...
Old 08-31-2011, 01:33 PM
OP
Here's a list of what should be done.
Spark Plug Change (manual recommends at 105k but you'll be lucky if the spark plug seals dont fail before them, if they havent already)
Transmission Drain and Fill
Rear Diff Drain and Fill
Coolant Drain and Fill
Compression Rod Bushings could be contributing to a less than stellar ride comfort so get those checked as well as the shocks/struts
The following 2 users liked this post by Gdup35sedan:
FRISCO6MT (08-31-2011), moto_za (08-31-2011)
Old 08-31-2011, 11:43 PM
NISMOKC's Avatar
i have a 04 MT coupe at 120xxx miles, owned it for 3 years now since 50xxx
kept up on oil changes and belts
about to do trans & diff fluids and spark plugs
coolant is good
but my tensioner pulley on the drivers side is squeaking, not all the time but often in and out. the bearing is messed up so i need to replace it
suspension feels fine
all i have is tien h-tech springs, put them on around 65xxx miles
other than that its just as fun as the day i bought it
chinee
04-19-2021 09:18 PM
derres
08-28-2015 03:27 PM
EPG35
08-16-2015 04:52 PM
iknowitsfast
08-12-2015 02:08 AM
noctilucous
2nd Gen (V36) Sedan
08-06-2015 08:47 PM
Quick Reply: 75,000 mile maintenance, any advice?
