2003 G35 Belt replacement parts simplified
Mods maybe a sticky for this one to help people find the sure answer for this one in a hurry. Most the other threads confuse more than anything.
If you are looking to replace your AC compressor and Accessory (alternator and fan) belt I have the correct numbers for you. I just completed the replacement using Gates belts. The long and short of it is AC compressor should come in a longer and a shorter version. If you have the mechanical clutch fan assembly and not the electronic fan you need the longer belt which is 38" or 37 7/8" outside circumference belt. If you have electronic fans you need the shorter belt which is 37 1/8" or 37 1/8" outside circumference belt.
AC BELT
Mechanical fan = K040372 or some variation ending in 372 i.e. 404372 or similar (38" or 37 7/8" outside circumference belt - LONG BELT)
other number listed on package is 4PK949 (not sure of its significance but may come in handy for other brand belts.)
Electronic fan = K040365 or some variation ending in 365 i.e. 404365 or similar (37 1/8" or 37 1/8" outside circumference belt - SHORT BELT)
ACCESSORY BELT
Accessory Belt = K060465 or some varation ending in 465 (this is a 47" belt)
I hope I have simplified this as much as possible. For what its worth the date code on my car inside the door seal of the driver's door indicated 10/2002. Also parts were purchased at O'reilly's Auto Parts. Now all squealing is gone
Long AC Belt (early 2003 mechanical fan)
http://www.oreillyauto.com/site/c/de...0074&ppt=C0007
Short AC Belt: (late 2003 electric fan)
Accessory Belt:
AC BELT
ACCESSORY BELT
Accessory Belt:
Hasanbaloch
02-29-2024 08:45 PM
TWASkyliner
02-08-2020 08:00 PM
2003, 35, ac, alternator, belt, belts, compressor, g35, g35belt, infiniti, interval, replace, replacement, sedan, size
