"best" settings for JL 500/1 amp
Old 08-08-2005, 03:29 PM
G-ThreeFizzle's Avatar
Hey Everyone,
My friend and I just installed a JL 10W6V2 sub in my car last Friday. It sounds good, but for some reason, it just doesn't seem like I'm getting the most out of this sub. It hits really smooth, but just not enough "oomph" if you know what I mean? I know alot of people on this board have this setup, so can anyone tell me what the "optimal" settings I should have on my JL 500/1 amp to produce the best overall sound? Thanks guys.
~ Fizzle
Old 08-08-2005, 03:43 PM
ryanwiggum's Avatar
Originally Posted by G-ThreeFizzle
Hey Everyone,
~ Fizzle
set your gains accordingly. if the bass doesn't hit as hard as you want it to, then you might want something a little more powerful
Old 08-08-2005, 04:53 PM
Silverio's Avatar
Based on the specs of that JL500/1 and that sub you shouldn't have a problem driving the sub to it's full potential. I think a lot of people use just the 300/1 and are fine but the 500/1 should be more than enough. I know it takes a while for some subs to really break in but the other problem could be power. What size power cable are you running and do you have a decent battry? Unfortunately I do not have my setup yet but that's what I plan on going with so we'll see what kind of answer you get here. Anybody got any ideas??
Old 08-08-2005, 07:07 PM
I have 4 AWG wires running from my car battery to the amp, so I shouldn't see a problem there. Maybe I'm just being too picky because I used to have 2 12" Kicker's in my old Maxima .
Old 08-08-2005, 07:23 PM
IPon6MT's Avatar
im no audio pro, but messing with the gain should boost up that amp.. I have the 500/1 with JL 10W6V2 (inside 4080 box) and mine rocks pretty good.. takes your breathe away. I like it! I notice you're in SoCal.. where about?? I can let you listen to mine and see if that's the right amount of boom you wanted, or if you even want more. but this setup is good enough for me..
oh yeah, Sound Advice in Mission Viejo performed my install and they did a great job! very accomodating and proffessional!
Im running my setup on a stock battery, so the power should be enough. Now if you were going with two 500/1 or a 1000/1 or some other variations, then you will need more power.. but with your current setup, your stock battery should suffice.
lemme know..
Old 08-08-2005, 07:26 PM
MikeyMike's Avatar
Rollin On Dubz
I"m having the same problems man, I've got a 500/1 hooked up to a 12w7. I gotta take it back to my installer, cuz this thing is not hitting hard at all
Old 08-08-2005, 07:30 PM
SWAT311's Avatar
It could also be your audio source. If the HU volts are low you will not be getting maximum use out of the amp. Are you running with the stock HU? If so hows your high/low converter? Might want to look into a line driver or an EQ, Audio Control makes some decent ones.
What kind of Kicker's did you have in your Maxima? I had four 15" L7's in my Tahoe and I loved every inch of those things. If your going for pure thumb, I def. recommend Kicker.
Good luck w/ fine tuning your system.
Old 08-08-2005, 07:37 PM
Hey Ipon,
I don't know where to "mess" with the gain per se. I'm definitely no audio expert as well. Anyhow, I currently live in Cerritos but used to live in Irvine (Graduated from UCI a year ago). Any info would be appreciated. Thanks again.
Old 08-08-2005, 10:47 PM
ryanwiggum's Avatar
lemme know..
setting the gains too high could damage the speaker(s)
Old 08-09-2005, 02:41 AM
sfgr415's Avatar
On JL amps, there is a voltage input (low/high). This is crucial as you must enter the correct one. I belive the cut off for what is considered low/high is 4 volts.
Old 08-09-2005, 07:55 AM
googe's Avatar
man i only have a 10w3 and it hits pretty good! you should definitely not have doubts with the w6!
Old 08-09-2005, 01:03 PM
ryanwiggum's Avatar
Old 08-09-2005, 01:12 PM
Silverio's Avatar
Ipon, any luck yet with this? Did the voltage input that sfgr415 mentioned above help? Curious because again seems like that 500 should push that easily. Let us know.
Old 08-09-2005, 05:11 PM
HOO-MAN?'s Avatar
I Had A 1000/1 Jl Amp Pushing Two Jlw6v2's In A Ported Box... I Was Not Satisfied Either. I Went Up To Two 15's Instead. Now Its Too Much Bass. My Rear Deck Keeps Slamming Into My Rear Windsheild! I Just Cant Win....im Gonna Try Either One 13w7 Or Two 12 W7's. Any Reccomendations?
Old 08-09-2005, 10:32 PM
sfgr415's Avatar
If you were to go with 2 12w7's, you would have to get one more 1000/1 amplifier.
Quick Reply: "best" settings for JL 500/1 amp
